Creating a Raft Edge
With the Raft Edge command, the borders of the raft foundations of the concrete design that are not defined by the strips or shearwalls are defined. In some cases, some edges of the raft foundations are not covered with these elements, they are empty. In order to define raft foundation in these areas, the boundaries of raft foundation must be defined by the raft edge.
Location of Raft Edge Command
You can access it under the Concrete tab Foundation title in the ribbon menu.
To draw a raft edge:
  • Click on the Raft Edge icon in the ribbon menu .
  • The raft edge toolbar will be opened.
  • To create a raft foundation, you must create a closed area.
  • Create your first point for the closed polygon by clicking with the left mouse button in the drawing area.
  • You can draw a straight or perpendicular edge by pressing the shift key on the keyboard.
  • Repeat these steps to create your closed polygon.
  • Exit the command by pressing the esc key on the keyboard. You can now define raft foundation.
Creating the first point of the raft foundation edge
Obtaining a straight or vertical edge with the Shift key
Creating other edges for the raft foundation
Completing the creation of the raft foundation edge
Pile
