By using the "Command search" line at the top right of the ribbon menu interface, the searched command can be found and accessed via a shortcut and run automatically.
Usage steps:
Click the Search any command line in the ribbon menu.
For example, start typing Rectangular Column in the search line. As the command is typed, the matching commands will begin to be listed.
Select the rectangular column from the list.
The ideCAD will direct you to the rectangular column icon, then the command will run automatically.
