Transverse Reinforcement Detailing (BRD)
  • Transverse reinforcement detailing is applied automatically in accordance with Codes.
  • Transverse reinforcement detailing is applied according to Codes in earthquake resistant structure beams.
International Design Codes
ACI 318-19 : Transverse Reinforcement (BRD) per ACI 318-19 with ideCAD
TSC 2018 : Transverse Reinforcement Detailing for Beams.
Notation in ACI 318-19
bt = width of that part of cross section containing the closed stirrups resisting torsion, in.
ph = perimeter of centerline of outermost closed transverse torsional reinforcement, in.
Ve = design shear force for load combinations including earthquake effects, lb
ϕ = strength reduction factor
Details of transverse reinforcement are applied in accordance with Codes.
