Right Button Menu
In the Preferences dialog, if the right mouse button is pressed together with the "Ctrl" key when "Use right button for context menu" is checked, the last command that was executed becomes active.
In the Preferences dialog , if the right mouse button is pressed together with the "Ctrl" key when "Use right button for context menu" is not checked, the  right click menu opens.
