Classification of Sections for Ductility per AISC 341-16 with ideCAD
How does ideCAD control width-to-thickness Ratios according to AISC 341-16?
  • IdeCAD Structural automatically controls the width-to-thickness ratios of steel elements according to Table D1.1.
Rt = Ratio of the expected tensile strength to the specified minimum tensile strength, Fu
Pa = Required axial strength using ASD load combinations, kips (N)
Pu = Required axial strength using LRFD load combinations, kips (N)
Py = Axial yield strength , kips (N)
Ca = Ratio of required strength to available axial yield strength
E= Modulus of elasticity of steel = 29,000 ksi (200 000 MPa)
Width-to-Thickness Limitations of Steel and Composite Sections
The width-to-thickness ratios of compression elements should not exceed the limiting width-to-thickness ratios from AISC 341-16 Table D1.1, for members designated as moderately ductile or highly ductile members.
Limiting Width-to-Thickness Ratios for Compression Elements for Moderately Ductile and Highly Ductile Members
Description of Element
Width-to- Thickness Ratio
Example
λhd
λmd
Moderately Ductile Members
Flanges of rolled or built-up I-shaped sections, channels and tees; legs of single angles or double-angle members with separators; outstanding legs of pairs of angles in continuous contact
b/t
Flanges of H-pile sections per Section D4
b/t
not applicable
Stems of tees
d/t
Walls of rectangular HSS used as diagonal braces
b/t
Flanges of boxed I-shaped sections
b/t
Side plates of boxed I-shaped sections and walls of built-up box shapes used as diagonal braces
h/t
Flanges of built up box shapes used as link beams
b/t
Webs of rolled or built-up I shaped sections and channels used as diagonal braces
hw/t
Where used in beams or columns as flanges in uniform compression due to axial, flexure, or combined axial and flexure:
  1. Walls of rectangular HSS
  2. Flanges and side plates of boxed I-shaped sections, webs and flanges of built-up box shapes
b/t
h/t
Where used in beams, columns, or links, as webs in flexure, or combined axial and flexure:
  1. Webs of rolled or built-up I shaped sections or channels [b]
  2. Side plates of boxed I-shaped sections
  3. Webs of built up box sections
h/tw
h/t
h/t
For Ca ≤ 0.114
For Ca > 0.114
where
For Ca ≤ 0.114
For Ca > 0.114
where
Webs of built-up box sections used as EBF links
h/t
Webs of H-Pile sections
h/tw
not applicable
Walls of round HSS
D/t
