The Dome Gutter command creates an object on the dome edge by default, with a selected profile.
Location of Dome Gutter Command
You can access it under the 3D Geometric Objects title of the Ribbon menu, Facade tab.
Sweep Toolbar
Icons |
Sweep Draws a continuous form object according to the selected section. |
Ceiling cornice Draws a ceiling cornice object. |
Baseboard Draws a baseboard object. |
Border on wall Draws a border on the wall object. |
Cordon Draws a cordon object. |
Roof gutter Draws a gutter around the roof object. |
Dome gutter Draws a gutter around the dome object. |
Parent based Draws asweep while adhering to the contour of an object like zone etc. |
Sweep operations Opens an auxiliary toolbar with commands for changing sweep. |
Section list It is the list that allows the section of the sweep to be determined. A profile is selected from the list while drawing the object. |
Profiles Displays the folder of profiles saved in the project or to disk and allows sweep. |
Settings Displays the settings of the sweep. |
Click the Dome Groove icon from the Sweep toolbar .
The Parent Based mode in the toolbar is automatically active.
At the same time, the profiles to be used in the Dome Groove object are listed in the Section box .
If wanted, a different profile can be selected from the Section box.
Move the mouse over the dome and click the left button.
Dome Gutter will be formed around the dome.
Bringing the mouse over the dome
Creating the dome gutter by clicking the left mouse button
