With the Purlin Sheeting command, a sheeting element is created on purlin elements. Sheetings are load transfer elements.
Location of the Purlin Sheeting Command
Click the Sheeting icon from the ribbon menu.
Click on the Purlin Element group.
Edit your sheeting settings in the window that opens.
Press the OK button.
Before creating the purlin sheeting
Selection of purlin elements
After creating the purlin sheeting
