With the Round Plate Tube Base Plate command, steel column-foundation connections are defined.
Location of the Round Plate Tube Base Plate Command
From the connection menu, click the Round Plate Tube Base Plate icon.
From the Connection menu, click the Round Plate Tube Base Plate icon.
Click the column from the 3D perspective view.
Location of the Round Plate Tube Base Plate Connection Dialog
Stiffeners Tab
Stiffening for primary direction
Stiffening type in the primary direction is selected from the options. |
Preview
Plates and Grout Tab
Main plate
The main plate is determined by entering the value. The values to be entered are shown in the schematic drawing. |
Fitting plate 1/2
Fitting plates are determined by entering the value. The values to be entered are shown in the schematic drawing. |
Grout The value is entered for grout. The values to be entered are shown in the schematic drawing. |
Cast plate
The cast plate is determined by entering the value. The values to be entered are shown in the schematic drawing. |
Schematic drawing
Preview
Primary Stiffeners Tab
Stiffening plate
The stiffening plate is determined by entering the value. The values to be entered are shown in the schematic drawing. |
Schematic drawing
Preview
Chamfers Tab
Chamfers
Schematic drawing
Preview
Anchorage Tab
Primary direction
It is determined by entering the number of anchorages to be located in the primary direction and the distance values. The values to be entered are shown in the schematic drawing. |
Secondary direction It is determined by entering the number of anchorages to be located in the secondary direction and the distance values. The values to be entered are shown in the schematic drawing. |
Anchors
Anchor type is selected from the list. Anchor dimensions are determined by entering values. The values to be entered are shown in the schematic drawing. |
Bolt properties
Schematic drawing
Preview
Shear Assembly Tab
Shear key
One of the ready-made profiles is selected from the list as a shear key. By clicking on the Load section button, you can reach the ready section library and reach the list of American and European finished rolling sections and select from the list. |
Shear key length The shear key length is entered. The values to be entered are shown in the schematic drawing. |
Washer plate
The washer plate dimensions are determined by entering the values. The values to be entered are shown in the schematic drawing. |
Schematic drawing
Preview
Welds Tab
Welds
Schematic drawing
Preview
Design Data Tab
