Beam Design Limits.
  • Minimum beam depth is controlled automatically.
  • Deflection limits is controlled automatically.
International Design Codes
ACI 318-19 : Beam Design Limits per ACI 318-19 with ideCAD
TSC 2018 : Dimensional Limit Conditions for Beams
Notation
bf = effective flange width, in.
c1 = dimension of rectangular or equivalent rectangular column, capital, or bracket measured in the direction of the span for which moments are being determined, in.
c2 = dimension of rectangular or equivalent rectangular column, capital, or bracket measured in the direction perpendicular to c1, in.
Es = modulus of elasticity of reinforcement, psi
l = span length of beam or one-way slab; clear projection of cantilever, in.
sw = clear distance between adjacent webs, in.
ϕ = strength reduction factor
