Ribbon interface in the home, concrete, steel, modify etc. Once you click on any menu title, you will switch to that menu, and you will see the section and command icons under the menu.
To switch to the ribbon interface;
Click the Preferences icon from the ribbon menu Settings tab .
In the dialog that opens, in the General tab, check the Use Ribbon menu row.
When you restart the program, it will open with a ribbon interface.
