With the Rigid on Strong Axis Base Plate command, steel column-foundation connections are defined.
Location of the Rigid on Strong Axis Base Plate Command
You can access it under the ribbon menu, Connection tab, Experimentals title.
From the connection menu, click on the Rigid on Strong Axis Base Plate icon.
Click the column from the 3D perspective view.
Location of the Rigid on Strong Axis Base Plate Connection Dialog
Rigid on Strong Axis Base Plate Dialog
Plates and Grout Tab
Main plate
The main plate is determined by entering the value. The values to be entered are shown in the schematic drawing. |
Fitting plate 1/2
Fitting plates are determined by entering the value. The values to be entered are shown in the schematic drawing. |
Grout The value is entered for grout. The values to be entered are shown in the schematic drawing. |
Cast plate
The cast plate is determined by entering the value. The values to be entered are shown in the schematic drawing. |
Schematic drawing
Preview
Anchorage Tab
Primary direction It is determined by entering the number of anchorages to be located in the primary direction and the distance values. The values to be entered are shown in the schematic drawing. |
Secondary direction
It is determined by entering the number of anchorages to be located in the secondary direction and the distance values. The values to be entered are shown in the schematic drawing. |
Anchors
Anchor type is selected from the list. Anchor dimensions are determined by entering values. The values to be entered are shown in the schematic drawing. |
Bolt properties
Schematic drawing
Preview
Shear Assembly Tab
Shear key
One of the ready-made profiles is selected from the list as a shear key. By clicking on the Load section button, you can reach the ready section library and reach the list of American and European finished rolling sections and select from the list. |
Shear key length The shear key length is entered. The values to be entered are shown in the schematic drawing. |
Washer plate
The washer plate dimensions are determined by entering the values. The values to be entered are shown in the schematic drawing. |
Schematic drawing
Preview
Welds Tab
Welds
Weld electrode The strengths of the welding electrodes are defined in the design inputs. The strength of the main element in the weld joint is controlled under the condition that it has less strength than the weld strength. If necessary, click the list and define "Create New…". To create the welding electrode, give the information "Name" and "Weld metal tensile strength" in the dialog that opens after clicking "Create New". Welding geometry is determined automatically by the program. These properties can be changed to easily determine the connection properties. Geometry features are in accordance with industry standards and in the form specified in AISC. Welding geometry is determined automatically by the program. These properties can be changed to easily determine the connection properties. Geometry features are in accordance with industry standards and in the form specified in AISC. |
Schematic drawing
Preview
Design Data Tab
