Shear Wall Design Limits per ACI 318-19 with ideCAD
How does ideCAD control reinforced concrete shear wall design limits according to ACI 318-19?
  • The minimum wall thickness control is done automatically.
  • The user determines the wall dimensions.
:check_mark:
Notation
bw = the width of the web of the wall segment, in.
According to ACI 11.3.1.1, minimum wall thicknesses should follow ACI Table 11.3.1.1.
Wall type
Minimum wall thickness, h
Bearing
Gerater of:
4 in.
1/25 of the lesser of unsupported length and unsupported height
Nonbearing
Gerater of:
4 in.
1/30 of the lesser of unsupported length and unsupported height
Exterior basement and foundation
7.5 in.
Earthquake-Resistant Structures
Special structural walls
Concrete Shear Wall Design per ACI 318-19 §11, §18.10 The title also contains requirements for the dimensions and details of special structural walls and all components. Design provisions for special structural walls depend on the ratio of the wall dimensions, such as (hw/lw) and (lw/bw).
:check_mark:
