With the Welded Box/Tube Connection command, column-beam and beam-beam connections are defined.
Column-Beam
Beam-Beam
Location of the Welded Box/Tube Connection Command
From the Connection menu, click the Welded Box/Tube Connection.
The welded box/tube connection settings dialog will open.
Location of the Welded Box/Tube Connection Settings Dialog
Type Tab
Geometry
The gap value is entered. The values to be entered are shown in the schematic drawing. |
Element cutting method
One of the element cutting methods is chosen. The methods that can be selected are shown in the schematic drawing. |
Schematic drawing
Preview
Welds Tab
Welds
Weld electrode The strengths of the welding electrodes are defined in the design inputs. The strength of the main element in the weld connection is controlled under the condition that it has less strength than the weld strength. To create the welding electrode, provide the information "Name" and "Weld metal tensile strength" in the dialog that opens after clicking "Create New". Welding geometry is determined automatically by the program. These properties can be changed to easily determine the connection properties. Geometry features are in accordance with industry standards and in the form specified in AISC. |
Schematic drawing
Preview
Design Data Tab
