Sloping Vault Truss
With the Sloping Vault command, the sloping vault truss type which is one of the prepared truss types, is drawn quickly. Truss heights are adjusted from the truss settings.
Sloping Vault Truss Schematic Drawing:
Location of the Sloping Vault Command
  • Click on the sloping vault command.
  • In the Heights tab , enter the heights h2, h3 and h4 for sloping vault.
Entering 150 cm for h2, h4 and 200 cm for h3 in the height tab of the truss settings
Steel Slab
