Show/Hide Column Names and Sizes
If the column names and sizes are desired to be seen in the project, they are made visible from the "Layer Settings> Drawing Details" tab.
  • Click Settings/Element Properties/Layer  icon in the ribbon menu  .
  • Switch to this tab by clicking the Drawing Details tab in the Layer Settings dialog that opens  .
  • You will see a list of layers and sub layers.
  • Here, check the Column ID and Column Dimension row under the Column layer  .
  • When you exit the dialog by clicking the OK button, column names and dimensions will be visible in your plans.
Plan view with column names and dimensions hidden:
Plan view with column names and dimensions shown:
Creating 3D Text
