Set Auto Elevation
With the Set Auto Elevation command, ideCAD sees the object in the place where the library object will be created. It automatically detects the object elevation and places the library on it. If there is more than one object in the same place, object selection is made.
Location of Set Auto Elevation Command
You can access it from the Library toolbar that opens when the library command is clicked .
  • Click on the library command.
  • Activate Set Auto Elevation command from the toolbar.
  • Click on the point where you want to place your library.
  • Select the elevation (object) you want to place from the object selection dialog.
  • Place your library by clicking the left mouse button.
  • Your library will be placed in the elevation you selected.
Where to create a library
Determining the point where the object will be placed and fixing it by clicking the left mouse button
Selecting the elevation (object) where the library will be placed
Creation of the library
