With the Stiffened Shear Plate Connection command, beam-beam connection is defined.
Location of the Stiffened Shear Plate Connection Command
From the Connection menu, click on the Stiffened Shear Plate Connection.
TheStiffened shear plate connection settings dialog will open.
Location of the Stiffened Shear Plate Connection Settings Dialog
Type Tab
Connection type
One of the connection types is selected from the list. |
Plates
It is chosen whether the plates will be on the left, right or both sides of the beam. |
Schematic drawing
Preview
Plates Tab
Connection plate
Connection plate is determined by entering values. The values to be entered are shown in the schematic drawing. |
Stiffener plate
It is determined by entering the values of the stiffener plate. The values to be entered are shown in the schematic drawing. |
Schematic drawing
Preview
Top/Bottom Notch Tabs
Notch
If the option is selected, notching is done according to the entered values. The values to be entered are shown in the schematic drawing. |
Left flange cut
If the option is selected, left flange cutting is made according to the entered values. The values to be entered are shown in the schematic drawing. |
Right flange cut
If the option is selected, right flange cutting is made according to the entered values. The values to be entered are shown in the schematic drawing. |
Schematic drawing
Preview
Welds Tab
Welds
The thickness, type and angle values of the welds to be made at the joints are given. The information on whether it will be done on the construction site or not is entered. |
Weld electrode The strengths of the welding electrodes are defined in the design inputs. The strength of the main element in the weld joint is controlled under the condition that it has less strength than the weld strength. If necessary, click the list and define "Create New…". To create the welding electrode, give the information "Name" and "Weld metal tensile strength" in the dialog that opens after clicking "Create New". Welding geometry is determined automatically by the program. These properties can be changed to easily determine the connection properties. Geometry features are in accordance with industry standards and in the form specified in AISC.
Schematic drawing
Preview
Chamfers Tab
Cuttings (c2)
Schematic drawing
Connection cutting values are shown on the schematic drawing. |
Preview
Connection Bolts Tab
Horizontal arrangement
The horizontal arrangement distance value of the bolts is entered. The values to be entered are shown in the schematic drawing. |
Group 1
Bolt properties
Schematic drawing
Preview
Design Data Tab
