Dome Settings
With the Dome Settings command, settings such as dome width, height, elevation, segment count, drawing, material selection, structural material can be accessed.
Location of Dome Settings Dialog
The Dome, which appears after the dome command is run, is also available in the auxiliary toolbar.
In the Architectural Program
You can access under the ribbon menu Home tab, Roof title.
In Structural Program
You can access under the ribbon menu, Objects tab, Roof title.
General Tab
Dome ID
The dome name is entered.
Horizontal segment count
It determines how many horizontal parts (rings) the dome will be formed from. The more the number of pieces, the more rounded the dome lines are.
Vertical segment count
It determines how many vertical parts (slices) the dome will be formed from. The more the number of pieces, the more rounded the dome lines are.
Materials-Colors Tab
Visual material
The material to be used on the surfaces of the dome is selected from the list. Surfaces are covered with the selected material and displayed as such in renderings.
Texture length is entered into the world length. For example; If 1 is entered, the selected material texture is taken as 1 meter and covered on the relevant walls.
In the angle, the angle of the texture is entered.
Touch the U and V offset. The motion value in the x and y plane is entered.
With U and V mirroring, the texture is symmetrical with respect to the y and x planes.
By selecting the single material option, the material selected in "Outside material" is used on all surfaces of the dome
Line type
The line type of the line forming the dome is selected in the plan. Clicking the down arrow buttons to the right of the boxes opens the list of line types. From this list, the desired line type is selected by clicking with the left mouse button.
Structural Tab
Structural material
Select the static material to be used in the dome element from the list. Static material can be defined as a reinforced concrete element under Materials in Building Tree.
Dead load
Fixed external loads are entered, except for the reinforced concrete weight of the dome, which consists of thickness.
Live load
The moving load value to be used in the calculation of the dome is entered.
Finite element width
Enter the maximum finite element width to be taken as basis in shell calculation. The program analyzes shells by dividing them into trapezoidal form finite elements. Finite element width is automatically adjusted according to the shell shape, provided that it does not exceed the value entered in this row.
Components Tab
Add Building Components : Assigns the building materials defined for detailed building components metrics to the object.
  • Click on the building components button.
  • In this dialog, click on the folder related to the material from the list on the left. Click on the material you want to use.
In the usage section
Creating a Dome
