Column required strengths are calculated automatically.
Column design strengths are calculated automatically.
İnternational Design Codes
ACI 318-19 : Column Required and Design Strength
TSC 2018 : Axial Force and Biaxial Moment Interaction for Columns Column Shear Design Forces
Notation in ACI 318-19
D = dead load
E = earthquake load
L = live load
Lr = roof live load
R = rain load
S = snow load
U = strength of a member or cross section required to resist factored loads
W = wind load
ϕ = strength reduction factor
