Define Offset to Edge command shifts a previously defined sweep by the specified distance.
Location of Define Offset to Edge
You can access it from the Ribbon menu Modify tab under Entity Edit title.
Click the Define Offset to Edge icon.
Click the desired edge on the sweep you previously drew.
At this stage, enter the delay amount in the "Application Distance" box on the sweep operations toolbar.
When you click the left mouse button, the edge will be offset.
The initial version of the sweep
Selecting the edge to be offset
Creating a preview of the offset
Final version of the sweep
