Single Footing Drawings
With the Single Footing Drawings command, the project's single footing drawings are created.
Location of the Single Footing Drawings Command
  • Click the Single Footing Drawings icon.
  • The drawing properties dialog will open.
  • Make the edits you want and click the OK button.
  • Single footing will be designed automatically according to the scale and paper size specified in the drawing settings. It can create one or more single footing drawings windows depending on the size of the paper. The relevant window can be selected from the list under the Window menu.
  • In single footing details, footings are arranged as blocks with rebars and dimension lines. Especially since the moving work can be done a lot, the blocks make the moving process very easy. You can split the blocks into sub-blocks with the explode. In the sub-blocks, again, the object can be divided into lines and writings with explode.
General Tab
Specifications - Colors
Steel text
Steel line
Steel ID text
Steel ID circle
Total reinforcement length
Dimension text
Dimension line
Object ID
Object body
Specifications - Heights
Steel text
Steel ID
Steel - text distance
Dimension text
Dimension - text distance
Object ID
Font
Paper Tab
Paper width
Paper height
Scale (1/X)
Standard paper sizes
Vertical/Horizontal use
Distance between layouts
Left margin
Right margin
Top margin
Bottom margin
Border color
Text color
Advanced Tab
Draw steel bar ids
Draw steel lengths
Arrange blocks by name
Draw slab loads
Anchorage length is 1/4
Enable drawing organizer
All stories
Min. distance between blocks
Distance between lines
Table Settings Tab
Table
Table header
Text
Steel drawings
Draw steel bar table
