Splices.
  • Minimum clear spacing between the contact lap splice and adjacent splices or bars is controlled automatically according to Codes
  • Tension lap splice length and Compression lap splice length is controlled automatically in accordance with Codes.
İnternational Design Codes
ACI 318-19 : Splices
TSC 2018 : TSC Splices
Symbols in ACI 319-19
As = area of nonprestressed longitudinal tension reinforcement, in.2
ldc = development length in compression of deformed bars and deformed wire, in.
lsc = compression lap splice length, in.
lst = tension lap splice length, in.
Ktr = transverse reinforcement index, in.
f'c = specified comprehensive strength of concrete, psi
Stirrups.
