One-Way Slab Reinforcement Limits.
A minimum area of flexural reinforcement, is controlled and reported automatically.
A minimum area of shear reinforcement, is determined automatically according to Codes.
International Design Codes
ACI 318-19 : One-Way Slab Reinforcement Limits per ACI 318-19 with ideCAD
TSC 2018 :
Symbols in ACI 318-19
Aps = area of nonprestressed and prestressed longitudinal tension reinforcement, in.2
Av,min = minimum area of shear reinforcement within spacing s, in.2
fpu = specified tensile strength of reinforcement, psi
