Breadcrumbs
Setting New Contour Lines
In ideCAD, the axis border is defined according to the contour lines. Axis borders are automatically changed with new contour lines to be determined by giving corner points in the drawing area.
Location of the Contour Lines Command
You can access it under the ribbon menu, Home tab, Axis title in the architectural program.
You can access it under the ribbon menu, Concrete tab, Axis title in the structural program.
  • Click the Contour Lines icon.
  • Determine the corner points in the drawing area by clicking with the left mouse button.
  • Close the polygon (Click the first point again, the polygon will be closed).
  • The contour line will be defined.
Available contour lines
Creating the first point of new contour lines
Creating the second point of new contour lines
Creating the third point of new contour lines
Creating the fourth point of new contour lines
Closing new contour lines by clicking on the first point
Deleting existing contour lines and creating new contour lines
Calculate Contour
