End Plate Shear Connection
The end plate connection is a type of non-moment-transferring connection (slip connection) that is bolted to the body of the profile by welding. Bolt control, weld control and plate control are performed automatically according to the placement of the elements of the connection. Connection design with single plate is made automatically according to the Design, Calculation and Construction Principles of Steel Structures (ÇYTHYEDY) (GKT and YDKT) or AISC 360-16 (ASD and LRFD) regulations and the connection report is generated.
In the end plate connection calculation, distance control between bolts, horizontal and vertical edge distance control, weld thickness control, mounting stability controls are made as geometry control. As strength control, slip on support bolts, crushing in support profile and plate bolt hole, beam and plate slip slip, beam and plate shear failure, plate block slip, weld strength controls are made.
Connection Geometry
Geometry Checks
Bolt Spacing
ÇYTHYEDY 13.3.6
60 mm
20 mm
s =60 mm > smin = 3*16=48 mm
Horizontal Edge Distance
ÇYTHYEDY 13.3.7
40 mm
L eh ≥ 2d = 2 * 16 = 32 mm conformity check for application
22 mm
Minimum distance check according to Table 13.9
Vertical Edge Distance
ÇYTHYEDY 13.3.7
40 mm
22 mm
Weld Thickness
ÇYTHYEDY 13.3.7
5 mm
3.5 mm
Table 13.4
Erection Stability
ÇYTHYEDY 13.3.7
L
150 mm
190.4 mm
L=150 > 190.4/2=95.2 mm
Strength Checks
Bolt Shear at Support
ÇYTHYEDY 13.10b
Required
Available
Ratio
Control
31.564 kN
144,765 kN
0.218
Bolt Bearing on Support
16+2=18 mm
ÇYTHYEDY 13.3.13
Equation 13.14a and13.14b
Required
Available
Ratio
Control
31.564 kN
197,853 kN
0.160
Bolt Bearing on Plate
16+2=18 mm
ÇYTHYEDY 13.3.13
Required
Available
Ratio
Control
31.564 kN
334,399 kN
0.094
Beam Shear Yield
235.359 N/mm2
ÇYTHYEDY 13.17
Required
Available
Ratio
Control
31.564 kN
122,166 kN
0.258
Plate Shear Yield
235.359 N/mm2
ÇYTHYEDY 13.17
Required
Ready
Ratio
Control
31.564 kN
338.77 kN
0.093
Plate Shear Rupture
362.846 N/mm2
ÇYTHYEDY 13.18
Required
Available
Rate
Control
31.564 kN
287,374 kN
0.110
Plate Block Shear Rupture
235.359 N/mm2
362.846 N/mm2
1
ÇYTHYEDY 13.19
Required
Available
Ratio
Control
31.564 kN
308,556 kN
0.102
Weld Strength
480000 kN/m2
w
The weld thickness taken from the combination menu is 0.707 * w value. 5 / 0.707 = 7.07 mm
362.846  N/mm2
t
6.2 mm
l
135.856 mm
Required
Available
Ratio
Control
31.564 kN
91.688 kN
0.344
