With the Rebar Selection settings, the steel bar diameters to be used in the concrete design are selected. Reinforcement diameters selected from the Rebar Selection dialog are used in the design of concrete elements (column, beam, shearwall, slab, foundation, pile, retaining wall, etc.) .
Rebar Types
Rebar ID
Rebar types are listed. |
Diameter
The diameter values of the rebar types are listed. |
Area
The area value of the rebar types are listed. |
Type
The types used in rebars are listed. |
Load SI rebars Rebars of SI rebar type are loaded. |
Load US rebars Rebars of US rebar type are loaded. |
Load US metric rebars Rebars of US metric rebar type are loaded. |
Load Canadian rebars Rebars of Canadian rebar type are loaded. |
Load Australian rebars Rebars of Australian rebar type are loaded. |
Add new custom rebar Rebars of different diameters can be added. The Add New Custom Rebar dialog opens. The diameter and rebar id are entered, and the type is selected.
Delete selected rebars Deletes the selected rebar from the list. |
Move up Move up the selected rebar in the list. |
Move down Move down the selected rebar in the list. |
Column
Rebar ID
Diameter
Location of rebar and selection boxes
The location and dimensions of the listed rebars are selected by checking the boxes. |
Beam
Rebar ID
Diameter
Shearwall
Rebar ID
Diameter
Sub Basement Shearwall
Rebar ID
Diameter
Slab
Rebar ID
Diameter
Rib-Waffle
Rebar ID
Diameter
Strip Foundation
Rebar ID
Diameter
Raft Foundation
Rebar ID
Diameter
Single Footing
Rebar ID
Diameter
Foundation Tie
Rebar ID
Diameter
Stair
Rebar ID
Diameter
Shell
Rebar ID
Diameter
Pile
Rebar ID
Diameter
Retaining Wall
Rebar ID
Diameter
Well Foundation
Rebar ID
Diameter
