Reinforcement detailing is applied automatically in accordance with Codes.
İnternational Design Codes
ACI 318-19 : Column Reinforcement Detailing per ACI 318-19 with ideCAD
TSC 2018 : Longitudinal Reinforcement Detailing for Columns Transverse Reinforcement Detailing for Columns
Notation in ACI 318-19
dagg = Nominal maximum size of coarse aggregate, in.
db = Nominal diameter of bar, wire, or prestressing strand
Ktr = transverse reinforcement index, in.
ψe = factor used to modify development length based on reinforcement coating
ψg = factor used to modify development length based on grade of reinforcement
ψs = factor used to modify development length based on reinforcement size
ψt = factor used to modify development length for casting location in tension
