Reinforcement detailing of Joints is applied automatically in accordance with Codes.
For earthquake resistance structures reinforcement detailing of Joints is applied automatically in accordance with Codes.
International Design Codes
ACI 318-19 : Reinforcement Detailing of Joints per ACI 318-19 with ideCAD
TSC 2018 : Transverse Reinforcement Detailing for Beams. Column Transverse Reinforcement Detailing and Limits
Notation in ACI 318-19
ldc = development length in compression of deformed bars and deformed wire, in.
ldh = development length in tension of deformed bar or deformed wire with a standard hook, measured from outside end of hook, point of tangency, toward critical section, in.
ldm = the required development length if bar is not entirely embedded in confined concrete, in.
