Creating a Border on Wall
The border on wall command creates an object at the zone by default, with a selected profile.
Location of Border on Wall
Click the Border on Wall icon from the Sweep toolbar.
Sweep Toolbar
Icons
Sweep
Draws a continuous form object according to the selected section.
Ceiling cornice
Draws a ceiling cornice object.
Baseboard
Draws a baseboard object.
Border on wall
Draws a border on the wall object.
Cordon
Draws a cordon object.
Roof gutter
Draws a gutter around the roof object.
Dome gutter
Draws a gutter around the dome object.
Free drawn
Draws the sweep freely by giving a point without being attached to any object.
Path based
Draws a sweep based on the path object.
Parent based
Draws asweep while adhering to the contour of an object like zone etc.
Wall based
Draws the sweep attached to the wall.
Story top aligned
It automatically adjusts the level of the sweep to be the same as the story ceiling level and draws the object at that level.
Story bottom aligned
It automatically adjusts the level of the sweep to be the same as the story floor level and draws the object at that level.
Story alignment free
It takes the elevation of the sweep as much as the given level and draws the object at that level.
Sweep operations
Opens an auxiliary toolbar with commands for changing sweep.
Section list
It is the list that allows the section of the sweep to be determined. A profile is selected from the list while drawing the object.
Profiles
Displays the folder of profiles saved in the project or to disk and allows sweep.
Settings
Displays the settings of the sweep.
  • Click the Border on Wall icon from the Sweep toolbar .
  • Parent Based and Story Alignment Free in the toolbar are automatically active.
  • If desired, one of the free drawned, path based and wall based drawing modes can be selected.
  • Since the story alignment free mode is selected, the elevation value in the Sweep Settings dialog determines the height of the border from the base.
  • In the Section box in the Sweep toolbar, the profiles to be used in the border object are listed.
  • If wanted, a different profile can be selected from the Section box.
  • Move the mouse over the zone and click the left button.
  • The border will be formed on the wall at the specified elevation.
Bringing the mouse over the site
Creating a border on wall by clicking the left mouse button
Cordon Settings
