Exterior Veneer Settings
With the Exterior Veneer Settings command, the current exterior veneer type, height, material, unit dimensions settings can be accessed.
Location of the Exterior Veneer Settings Command
You can access it under the Ribbon menu, Facade tab, Exterior Facade title.
General Tab
Type
As the exterior veneer, one of the lap siding with gap, lap siding or terra cotta siding types is selected. After the selection is made, the dimensions for the selected type are set in the table on the right.
Unit dimensions
Give the dimensions of the exterior veneer unit element according to the references shown in the figure. While giving the dimensions, you can follow the change of the shape according to the entered dimensions from the front view below. Clicked size line is displayed in red in the preview.
Schematic drawing
Schematic drawings and dimensions of the unit belonging to the selected type are given.
Story height
It is drawn in the height value as much as the floor height value given in the floor general settings dialog.
Unit count
It is drawn in the height value as much as the given number of elements. The element height can be given as the unit height just above.
Value
It is drawn in height value as much as the entered value.
Elevation
It is the elevation value of the siding object relative to the story floor. Depending on the negative or positive value, the object is shifted up or down.
Vertical shift
It is the value that shifts the veneer piece up and down. For example, the veneer is defined on the 1st story and 2nd story. If there is not as much distance as the veneer piece between the 1st story and the 2nd story, the exterior veneer pieces can be proportional to the vertical shift.
Swap side
It takes the symmetry of the exterior veneer.
Show side indicator
In the plan drawing of the siding element, an arrow is shown indicating where the outeside is. This option determines whether that arrow is drawn in the plan.
Is under jamb
It extends the exterior veneer element under the jamb element, up to the window/door gap. If not marked, finish the exterior element at the edge of the jamb, surrounding the jamb.
Lay textures vertical
The coating texture assigned to the exterior element is placed perpendicular to the element surface. Otherwise, it is placed horizontally.
Show material in 3D
The 3 dimensional view shown on the right in the dialog is shown with the textures assigned to the exterior element. If not marked, the 3D image element appears painted with its own color.
Color
The siding is the color of the element. The desired color is selected from the color box.
Line type
It is the line type of the exterior veneer element visible in the plan. The desired line type is selected from the list.
Material
The material to be used on the siding and gap is selected from the list. Surfaces are covered with the selected material and displayed as such in renderings.
Texture length is entered into the world length. For example; If 1 is entered, the selected material texture is taken as 1 meter and covered on the relevant walls.
In the angle, the angle of the texture is entered.
Touch the U and V offset. The motion value in the x and y plane is entered.
With U and V mirroring, the texture is symmetrical with respect to the y and x planes.
By selecting the single material option, the material selected in "Siding material" is used on all surfaces of the exterior veneer.
3D preview
It is the front view of the siding. The image will also change in accordance with the type of coating selected on the top. The dimensions for the respective facade covering are also shown in the image. Dimensions for the selected type can be set in the table above the image.
Components Tab
  • Click the Add Building Component button.
  • In this dialog, click the folder related to the material from the list on the left. Choose the material you want to use.
In the usage section
Following are the lines that appear in the proportion list according to the exterior veneer and material size.
Exterior Veneer
Measure
Listed
Explanation
Constant
Independent
Length
Independent
Length
It means that the length of the material will be found by multiplying the length measure found while defining the material by the element length.
Area
Independent
It means that the area measure found while defining the material will be used exactly as the amount.
Outside area
It means that the area measure found while defining the material will be used by multiplying the element outside area.
Volume
Independent
The volume measure found when defining the material will be used exactly as the volume of the material.
Volume
It means that the volume measure found when defining the material will be used by multiplying the volume of the element.
Count
Independent
The number measure found while defining the material will be used exactly as the material number.
Count
It means that the measure of number found when defining the material will be used by multiplying the number of elements.
