For DTS = 3, Mdev / Mo> = 0.75 must be provided.
The Complete Message:
In earthquake design class (DTS) 3 or 4 unidirectional geared reinforced concrete structural systems, the condition Mdev / Mo> = 0.75 must be met.
According to article 4.3.4.6 of TBDY , ductility level should be provided in mixed structural systems (4.3) .
                                                              ∑ M DEV ≥ 0.75 M o                                                       (4.3)
Possible solutions:
  • Shearwall / shearwall group can be added to the structural system until the 4.3 condition is met.
  • If the building height class is BYS> = 7, a solution can be made by selecting A31 .
Icons:
