Column-Beam Joint Cross-Section Detail
Colour, size, type and paper settings of the texts belonging to the column-beam joint cross-section are arranged.
General
Specifications - Colors
Steel line
Object ID
Object body
Specifications - Heights
Font
Paper
Paper width
Paper height
Scale (1/X)
Standard paper sizes
Vertical/Horizontal use
Distance between layouts
Left margin
Right margin
Top margin
Bottom margin
Border color
Text color
Advanced
Draw steel bar ids
Draw steel lengths
Arrange blocks by name
Draw slab loads
Anchorage length is 1/4
Enable drawing organizer
All stories
Min. distance between blocks
Distance between lines
