Composite beam design results and composite beam failures are displayed in the Composite Beams dialog. When the definition of composite slab is made on the secondary steel beams, composite beam design is made for these elements. In the Composite Beams dialog, composite steel beam properties (concrete effective width, composite section neutral axis, composite moment of inertia), construction phase bending moment control, composite bending control, shear control and deflection control are given.
Location of Composite Beams Dialogue
After the analysis is done, you can access it by clicking the Composite Beam Design Results command under the Steel Design title of the ribbon menu Analysis and Design tab .
General Specifications of Composite Beams Dialogue
Summary Information The summary information about the line where the cursor is located is given in the name of the dialog in story, pose format.
For example, STORY 2, SB001 |
Using the Shift key In this tab, you can select more than one row with the Shift key, enter a value by double-clicking any cell whose value is open to change, and make that value apply to all selected rows. |
Using the Ctrl key Ctrl key selects the lines in between one by one. |
OK It saves the changes made and closes the dialog. |
Composite Beams
Design Checks Tab
ID
It is the name of the composite beam in the plan. |
Section
It is the section used in composite beam. |
Material
It is the material class of composite beam. |
PCC
It is the composite ratio of the element. |
Construction bending
It is the bending moment during the construction phase. |
Composite bending
It is the ratio of bending moment to capacity. |
Shear
It is the ratio of cutting force to cutting capacity. |
Deflection
It is the ratio of total deflection to the upper value. |
Check
It is an information box whose sign changes according to the presence or absence of negativity in the section. |
Design Details Tab
Schematic drawing
Composite status
Number of studs: The number of slip nails in the element.
Combo: The load combination that produces the most unfavorable construction bending moment ratio.
Composite bending
Combo: The load combination that produces the most unfavorable composite bending moment ratio.
Shear
Combo: It is the load combination that produces the most negative shear rate.
Composite section properties
Effective width of the concrete slab: It is the parameter used in composite beam design and calculated in accordance with the definition given in ÇYTHYEDY SECTION 21.4.1.1.
Deflection
