One-Way Slab Design Limits per ACI 318-19 with ideCAD
How does ideCAD control one-way slab design limits according to ACI 318-19?
  • The minimum slab thickness is controlled and reported automatically according to Table 7.3.1.1.
  • For nonprestressed slabs not satisfying 7.3.1, immediate and time-dependent deflection is calculated according to 24.2 and is not exceed the limits in 24.2.
  • Slab thickness is detemined by user.
l = span length of beam or one-way slab; clear projection of cantilever, in.
:check_mark:
Design limits
Minimum Slab thickness
The minimum slab thickness is controlled automatically according to Table 7.3.1.1. If calculated deflection limits of 7.3.2 are satisfied, the minimum slab thickness condition is not controlled.
Support Condition
Minimum slab thickness, h
Simply supported
l/20
One end continuous
l/24
Both ends continuous
l/28
Cantilever
l/10
For fy other than 60,000 psi, the expressions in Table 7.3.1.1 are multiplied by (0.4 + fy/100,000).
Calculated deflection limits
For nonprestressed slabs not satisfying 7.3.1, immediate and time-dependent deflection is calculated according to 24.2 and does not exceed the limits in 24.2.2.
Reinforcement strain limit in nonprestressed slabs
It’s automatically designed according to Strength Reduction Factors per ACI 318-19 with ideCAD.
:check_mark:
