In this section, share the ide YAPI information model as dwg or dxf.
Previous steps were applied in the project file named Collaborate Using DWG DXF. |
You can save architectural projects prepared with ideCAD Architecture in DWG/DXF/DWF formats.
Click on the ideCAD logo in the upper left corner of the program.
Click Export/DWG/DXF/DWF from the drop-down menu.
In the dialog that opens, one of the dwg/dxf/dwf formats is selected from the Save as type line.
Type a name in the File Name line and click the Save button.
The DWG/DXF Export Options dialog will open. In this dialog, select the drawings you want to convert into dwg.
Select Centimeters as a drawing unit.
Your story plans, sections, elevations and layout will be converted to dwg file format.
Share the resulting files with the engineer.
Next Tutorial
