Torsional strength is calculated automatically.
İnternational Design Codes
ACI 318-19 : Torsional Strength per ACI 318-19 with ideCAD (v12)
TSC 2018 : TSC Torsional Strength
Notation in ACI 318-19
Ao = gross area enclosed by torsional shear flow path, in.2
Aoh = area enclosed by centerline of the outermost closed transverse torsional reinforcement, in.2
Acp = area enclosed by outside perimeter of concrete cross section, in.2
Al = total area of longitudinal reinforcement to resist torsion, in.2
Al,min = minimum area of longitudinal reinforcement to resist torsion, in.2
At = area of one leg of a closed stirrup, hoop, or tie resisting torsion within spacing s, in.2
(fc')0.5 = square root of specified compressive strength of concrete, psi
fpc = compressive stress in concrete, after allowance for all prestress losses, at centroid of cross section resisting externally applied loads or at junction of web and flange where the centroid lies within the flange, psi.
Nu = factored axial force normal to cross section occurring simultaneously with Vu or Tu; to be taken as positive for compression and negative for tension, lb
pcp = outside perimeter of concrete cross section, in.
ph = perimeter of centerline of outermost closed transverse torsional reinforcement, in.
Tcr = cracking torsional moment, in.-lb
Tth = threshold torsional moment, in.-lb
ϕ = strength reduction factor
λ = modification factor to reflect the reduced mechanical properties of lightweight concrete relative to normal weight concrete of the same compressive strength
