With the Change Dormer Roof Angles command, the angles of the surfaces forming the dormer are changed.
Location of Change Dormer Roof Angles Command
You can access the Change dormer roof angles command from the dormer toolbar.
Click the Change Dormer Roof Angles icon from the dormer toolbar .
Roof angle modification is valid for single, double and triple dormer objects.
There is no surface angle in round and spline types. Click one of these objects.
A dialog will open where you can change the angle of the surface according to the dormer type you selected.
Enter values in degrees or percentages in the dialog.
Click the OK button.
Dormer before changing the roof angle
Selection of dormer to be changed roof angle
Changing surface angles
Dormer after changing roof angle
