Definition of Walls with Coupling Beam (4.5.4.1)
  • The beams between the curtains are automatically controlled for the degree of commitment.
Curtains with reinforced concrete tie beams (hollow) are vertical carrier system elements in which two non-gap curtain parts work together as a single curtain by connecting with tie beams with short and very high shear strength . If there is a beam in X and Y directions between two walls, ideCAD automatically checks the gap curtain condition .
