Shear Wall Reinforcement Detailing.
  • Reinforcement detailing is applied automatically in accordance with Codes.
International Design Codes
ACI 318-19 : Shear Wall Reinforcement Detailing per ACI 318-19 with ideCAD
TSC 2018 : Web Reinforcement Limits and Detailing for Shearwalls
Notation in ACI 318-19
db = Nominal diameter of bar, wire, or prestressing strand, in.
Ktr = transverse reinforcement index, in.
ψe = factor used to modify development length based on reinforcement coating
ψg = factor used to modify development length based on grade of reinforcement
ψs = factor used to modify development length based on reinforcement size
ψt = factor used to modify development length for casting location in tension
Concrete cover for reinforcement should be in accordance with Codes. Concrete cover is measured to the outer edge of ties, stirrups, or spirals if transverse reinforcement encloses main bars.
