Materials and Reduction Factors.
  • Design properties for concrete and reinforcement materials are selected by user.
  • Modulus of elasticity and Shear Modulus is calculated automatically according to the selected material’s design property.
  • Strength Reduction Factors are selected by user.
The nominal strength of a reinforced concrete member is calculated automatically using the selected Strength Reduction Factor.
İnternational Design Codes
ACI 318-19 : Materials and Reduction Factors per ACI 318-19 §19, §20, and §21
TSC 2018 : TSC Sectional Strength
Materials
The design properties of the concrete material are to be selected in accordance with Codes.
The design properties of the reinforcement material are to be selected in accordance with Codes.
Strength reduction factor used in the sectional design is determined according to Codes.
