Slab Design Settings Section
With the Slab Design Settings the design parameters used in the concrete slab design are determined. Concrete cover, maximum and minimum reinforcement interval, etc. parameters are determined from the Slab Design Settings window.
For instance:
  • A minimum reinforcement ratio of 1% corresponds to a steel area equal to 1% of the concrete section.
  • Since a reinforcement ratio of 0.01 (i.e. 0.01 × 100) equals 1%, the value “1” should be entered for this parameter.
Concrete cover
It is the distance from the center of gravity of the tensile rebar inside the slab to the outer surface of the concrete.
Min. main tensile percentage
In slab floors working in two directions, it is the tensile percentage in the short edge direction of the slab. This parameter should be written as a percentage. In the slab calculation axis span, the rebar area is calculated from the moment value found as a result of analysis + design. This area is also compared with the minimum rebar area calculated using the Minimum Tensile Percentage. The area that is larger is used.
Min. other tensile percentage
In slab floors working in two directions, it is the tensile percentage in the long edge direction of the slab. This parameter should be written as a percentage. In the slab calculation axis span, the rebar area is calculated from the moment value found as a result of analysis + design. This area is also compared with the minimum rebar area calculated using the Minimum Other Tensile Percentage. The area that is larger is used.
Min. one-way percentage
In slab floors where the long side is twice as long as the short side, it is the tensile percentage in the short edge direction. This parameter should be written as a percentage. In the slab calculation axis span, the rebar area is calculated from the moment value found as a result of analysis + design. This area is also compared with the minimum rebar area calculated using the Minimum One-Way Percentage. The area that is larger is used.
Min. one-way other percentage
In slab floors where the long side is twice as long as the short side, it is the tensile percentage in the long edge direction. This parameter should be written as a percentage. In the slab calculation axis span, the rebar area is calculated from the moment value found as a result of analysis + design. This area is also compared with the minimum rebar area calculated using the Minimum One-Way Other Percentage. The area that is larger is used.
Min. reinforcement interval
This parameter is taken into account when selecting rebar in slab floors. If the distance between two rebars is less than the minimum rebar spacing, the rebar diameter is increased.
Max. reinforcement interval
The distance between two rebars cannot be more than the value entered in this parameter. The maximum range of rebar is used together with the x * d parameter.
Max. reinforcement interval x*d
The value entered in this parameter is multiplied by the thickness of the plate. The value found is the maximum rebar range and the distance between two rebars cannot be more than the value calculated from this parameter.
Min. reinforcement interval (Aux)
It is the parameter that limits the minimum distance between additional rebars in slabs. This parameter is taken into account when selecting additional rebars in slabs. If the distance between two additional rebars is less than the minimum rebar spacing, the rebar diameter is increased.
Max. reinforcement interval (Aux)
It is the parameter that limits the distance between two additional rebars in slabs. The distance between two additional rebar is not chosen more than the value written here. The maximum rebar spacing is compared with the parameter x * d and the smaller one is used.
Max. reinforcement interval (Aux) x*d
It is the parameter that limits the maximum distance between additional rebars in slabs. Plate thickness is diametered with the value entered in this parameter. The value found is the maximum rebar range and the distance between the two rebars is not chosen more than the value calculated from this parameter.
Minimum extra rebar length
It is the parameter that determines the minimum length of additional rebar in slabs.
Extra rebar length rounding factor
The length of additional reinforcement in slabs is the parameter that determines the rounding coefficient.
Rebar shape
The shape of the rebar in the slab is determined. If it will be designed as additional straight aux. rebar, if it will be designed as flat or pleated, choose the option to add piles.
Use multiple of 5 rebar intervals
If the option is selected, the program enables the selection of rebar spacing in multiples of 5 and 5. The option is not checked, the rebar range is put as much as required for the calculation.
