Creating an Ellipse Center-Corners
Ellipse Center-Corners command is one of the three ellipse drawing techniques. An ellipse is created by specifying a center, a corner point.
Location of the Ellipse Center-Corners Command
In the Architectural Program
You can access it under the ribbon menu Drawings tab, Primitives title
In the Structural Program
To draw an ellipse using this command:
  • Click the Ellipse Center-Corners icon in the ribbon menu .
  • Click any point in the drawing area with the left mouse button. This point will be the center of the ellipse to be drawn.
  • Drag the mouse. Depending on the movement of your mouse, a preview of your ellipse will be created.
  • Select a second point by clicking the left mouse button.
  • An ellipse will be drawn.
Determining the first point of the ellipse
Previews due to mouse movement
Determining the second point of the ellipse
Creation of the ellipse
