Wall required strengths are calculated automatically.
Wall design strengths are calculated automatically.
International Design Codes
ACI 318-19 : Shear Wall Required and Design Strength per ACI 318-19 with ideCAD
TSC 2018 : Shearwall Design For Flexure and Axial Force Shear Design of Shearwalls
Notation in ACI 318-19
D = dead load
E = earthquake load
L = live load
Lr = roof live load
R = rain load
S = snow load
U = strength of a member or cross section required to resist factored loads or related internal moments and forces in such combinations
W = wind load
ϕ = strength reduction factor
