Cone-Pyramid Settings
With the Cone-Pyramid Settings command, settings such as elevation, height, axis of rotation, radius, segment counts and material selection are accessed.
Location of Cone - Pyramid Settings Command
Click on the Cone - Pyramid icon from the Tubes toolbar opened after entering the Tube command under the Entities title of the ribbon menu Home tab . After entering the Cone - Pyramid command, you can access it by clicking the Settings icon.
Properties Tab
Color
Select the color of the cone object from the color palette that opens when clicked.
Line type
Select the line type of the cone object that appears in the plan from the drop-down list when clicked.
Material
Select the material of the object from the material list that opens when clicked.
Tile X/Y
Determines the number of times to repeat the texture to be wrapped around the object in the X and Y direction.
Spherical coordinate/Horizontal
It is the angle that the axle makes with the horizontal (x-axis).
Spherical coordinate/Vertical
It is the angle that the axis makes with the vertical (z-axis).
Vectoral X / Y / Z
Coordinate values ​​that express the vector direction of the rotation axis.
Node elevation
The object is elevated according to the floor base.
Segment count
It is the value that determines the number of surfaces of the object to be created.
Height
It is the height of the created object.
Radius
The radius of the object is entered.
Cover
The surfaces to be left open or closed respectively are marked. If it is checked, the relevant surface is closed.
3D preview
It is a 3D view of the cone object. You can rotate the image around itself by holding down the left mouse button and moving it. You can zoom in and out by holding the right mouse button and moving the mouse.
Components Tab
  • Click the Add Building Component button.
  • In this dialog, click the folder related to the material from the list on the left. Choose the material you want to use.
In the usage section
Following are the lines that appear in the proportion list according to the cone-pyramid and material size.
Cone-Pyramid
Measure
Listed
Explanation
Constant
Independent
Length
Independent
Length
It means that the length of the material will be found by multiplying the length measure found when defining the material and the length of the object.
Area
Independent
It means that the area measure found while defining the material will be used exactly as the field value.
Outside area
It means that the area measure found while defining the material will be used by multiplying the element outer area.
Volume
Independent
It means that the volume measurement found when defining the material will be used exactly as the volume value.
Volume
It means that the volume measure found when defining the material will be multiplied by the object volume.
Count
Independent
The number measure found while defining the material will be used exactly as the number value.
Count
