Defining a End Plate Truss Connection
With the End Plate Truss Connection command, column-truss connection is defined.
Location of the End Plate Truss Connection Command
You can access it under the ribbon menu, Connection tab, Experimentals title.
  • From the connection menu, click on the End Plate Truss Connection row.
  • Select the main element (column) and click the right mouse button.
  • Select the truss elements connected to the main element and click the right mouse button.
Location of the End Plate Truss Connection Dialog
Plates Tab
End plate
The end plate is determined by entering the value. The values ​​to be entered are shown in the schematic drawing.
Schematic drawing
Preview
Main Plate Tab
Plate dimensions
The plate is determined by entering the value. The values ​​to be entered are shown in the schematic drawing.
Schematic drawing
Preview
Plate Type Tab
Type
One of the connection types is selected from the list.
Dimensions
Plate sizes are determined by entering values. The values ​​to be entered are shown in the schematic drawing.
Schematic drawing
Preview
Bolts Tab
Horizontal arrangement
Group 1
Bolt properties
Schematic drawing
Preview
Welds Tab
Welds
Weld electrode
Schematic drawing
Preview
Truss Bolts Tab
Group 1
Bolt properties
Schematic drawing
Preview
Design Data Tab
