Different drawing modes can be used when drawing sweeps. There are 4 different drawing modes in the program: Free Drawn, Path Based, Parent Based , Wall Based . These are in addition to story top aligned, story bottom aligned and story alignment free drawing mode with alignment options are available.
The drawing modes that can be used vary according to the sweeps. Which drawing modes can be used for which objects are given in the table below.
Free Drawn
Free drawn by giving points without being attached to any object. It becomes active on sweep, ceiling cornice, baseboard, border on the wall and cordon.
You can activate it from the sweep toolbar.
For example, in this mode, 1, 2 and consecutive points are clicked to draw a sweep.
Determining the first point by clicking the left mouse button
Creating a sweep
Path Based
Draws a sweep based on the path. It becomes active on sweep, ceiling cornice, baseboard, border on the wall and cordon.
For example, in this mode, the line drawn with the path command is clicked to draw a sweep.
Determining the route by path
Choosing the route
Creating a sweep
Parent Base and Story Bottom Aligned
It draws a sweep by adhering to the contour of an object such as zone, slab, etc. with a parent base. It becomes active on sweep, ceiling cornice, baseboard, border on the wall, roof gutter and dome gutter.
With Story Bottom Aligned, it automatically adjusts the object elevation to be the same as the story level and draws the object at that elevation. It becomes active on sweep, ceiling cornice, baseboard, border on the wall and cordon.
For example, in these modes, click on the area to draw a baseboard.
Choosing the zone
Formation of the baseboard
Wall Based and Story Alignment Free
With Wall Based , draws the object attached to the wall. It becomes active on sweep baseboard, border on the wall and cordon.
With Story Alignment Free , it takes the elevation of the object as much as the given elevation and draws the object at that elevation. You can make the elevation from the sweep settings dialog. It becomes active on sweep, ceiling cornice, baseboard, border on the wall and cordon.
For example, in these modes, walls are selected to draw borders on the wall.
Choosing the walls
Formation of a border on the wall
Story Top Aligned
Story Top Aligned automatically adjusts the object elevation to be the same as the story ceiling elevation and draws the object at that elevation. It becomes active on sweep, ceiling cornice, baseboard, border on the wall and cordon.
For example, in this mode, slab is selected to draw ceiling cornice.
Choosing the slab
Formation of ceiling cornice
