When the slab is defined, it defines two slab calculation axes in the horizontal and vertical directions based on the middle of the slab. With the "Concrete/Slab/Change concrete calculation line geometry" command, the position and/or working distance of a drawn calculation axis is changed.
Usage steps:
Click on the "Concrete/Slab/Change concrete calculation line geometry" command.
Click on the slab calculation axis, give the new position.
Click on the line showing the story working distance, give the new position.
