Beam deflection limit exceeded
The deflection value of the beam means that it exceeds the upper deflection limit.
This message is created at the beginning of the report by giving the element name and solid.
For example, K01 1st floor Beam deflection limit has been exceeded.
The deflection control of the beams is made according to the principles given in TS 500 13.2 .
Solution:
Increase the dimensions of the beam, whose name and solid is given, until the deflection condition is met.
Repeat the analysis after the size increase.
