Bolted Flange Plate Connection Design
Bolted Flange Plate Connection is formed with header plates welded to the column head and bolted to the beam head. Bolt control, weld control, plate control and joint application limits control are performed automatically according to the placement of the elements of the joint. Head Plate Bolt Joint design is made automatically according to the Design, Calculation and Construction Principles of Steel Structures (ÇYTHYEDY) or AISC 360-16 regulations and a joint report is created. Joint detail application limits are checked according to TBDY Table 9B.2.
In the calculation of Head Plate Bolt Joint, horizontal and vertical bolt distances, butt plate weld thickness, continuity plate weld thickness and application limits are checked under geometry control. Bolt diameter in strength control, slip in cap and body bolts, crush in cap and body bolt hole, crush in beam cap bolt hole, head plate tensile yield and tensile failure, block slip in head plate and beam head, beam and body plate shear failure, block in body plate slip, body plate bending yield, slip plate column head weld strength, column panel region slip and slip region thickness control are performed.
Connection Geometry
Geometry Checks
Bolt Spacing at Flange
ÇYTHYEDY 13.3.6
84 mm
27 mm
s =84 mm > smin = 3*27=81 mm
Horizontal Edge Distance at Flange
ÇYTHYEDY 13.3.7
60 mm
L e ≥ 2d = 2 * 27 = 54 mm conformity check for application
36 mm
Minimum distance check according to Table 13.9
Vertical Edge Distance at Flange
ÇYTHYEDY 13.3.7
50 mm
Check suitability for L e ≥ 2d = 2 * 27 = mm application
36 mm
Weld Thickness
ÇYTHYEDY 13.3.7
9 mm
3.5 mm
Table 13.4
Bolt Spacing at Web
ÇYTHYEDY 13.3.6
72 mm
24 mm
s =7 mm > smin = 3*24=72 mm
Horizontal Edge Distance at Web
ÇYTHYEDY 13.3.7
90 mm
Conformity check for L e ≥ 2d = 2 * 24 = 48 mm application
32 mm
Vertical Edge Distance at Web
ÇYTHYEDY 13.3.7
60 mm
L eh ≥ 2d = 2 * 24 = 48 mm conformity check for application
32 mm
Shear Plate to Column Flange Weld Size
a ≥ a min
ÇYTHYEDY 13.3.7
a
8 mm
a min
3.5 mm
Table 13.4
ÇYTHYEDY 13.3.7
8 mm
4 mm
Table 13.4
ÇYTHYEDY 13.3.7
8 mm
4 mm
Table 13.4
Connection Detail Prequalification Limits (TBDY Table 9B.2)
Beam span / Beam cross-section height
9144 mm /550 mm=16.63
≥9.0
Beam cross-section height, d b
550 mm
≤ 920
Beam head thickness, t bf
17.2 mm
≤25
Column cross section height
650 mm
≤ 920 mm
Bolt class
8.8
8.8 - 10.9
Bolt size
M27
≤ M27
Min yield stress of header plate material
275 MPa
235 /275 / 355 MPa
Title plate welding
CJP
CJP
Strength Checks
Bolt diameter
210 mm
Table 9B.3
1.40
235.359 N/mm2
1.10
362.846 N/mm2
Required
Available
Ratio
Control
15.32 mm
27 mm
0.567
Bolt Shear at Flange
Required
Available
Ratio
Control
1628.396 kN
1855.079 kN
0.878
Bolt Bearing on Flange Plate
27+3=30 mm
ÇYTHYEDY 13.3.13
Equation 13.14a and13.14b
Required
Available
Ratio
Control
1628.396 kN
5866.214 kN
0.278
Bolt Bearing on Beam Flange
27+3=30 mm
ÇYTHYEDY 13.3.13
Required
Available
Ratio
Control
1628.396 kN
279,455 kN
0.584
Flange Plate Tension Yield
275 N/mm2
ÇYTHYEDY 13.15
Required
Available
Ratio
Control
1628.396 kN
1848 kN
0.881
Flange Plate Tension Rupture
410 N/mm2
1.00
ÇYTHYEDY 13.16
Required
Available
Ratio
Control
1628.396 kN
1723.968 kN
0.945
Flange Plate Block Shear
275 N/mm2
410 N/mm2
1
ÇYTHYEDY 13.19
Required
Available
Ratio
Control
1628.396 kN
3636.864 kN
0.448
Beam Flange Block Shear
235.359 N/mm2
362.846 N/mm2
1
ÇYTHYEDY 13.19
Required
Available
Ratio
Control
1628.396 kN
1729.992 kN
0.941
Bolt Shear at Web
Required
Available
Ratio
Control
89.994 kN
146,574 kN
0.614
Bolt Bearing on Beam Web
24+2=26 mm
ÇYTHYEDY 13.3.13
Rn-spacing
Required
Available
Ratio
Control
246.43 kN
1000.454 kN
0.246
Bolt Bearing on Web Plate
24+2=26 mm
ÇYTHYEDY 13.3.13
Required
Available
Ratio
Control
246.43 kN
1227,442 kN
0.201
Web Plate Shear Yield
275 N/mm2
ÇYTHYEDY 13.17
Required
Available
Ratio
Control
246.43 kN
807.84 kN
0.305
Web Plate Shear Rupture
410 N/mm2
ÇYTHYEDY 13.17
Required
Available
Rate
Control
246.43 kN
712,022 kN
0.346
Beam Shear Rupture
410 N/mm2
ÇYTHYEDY 13.17
Required
Available
Ratio
Control
246.43 kN
891.709 kN
0.276
Web Plate Block Shear
275 N/mm2
410 N/mm2
1
ÇYTHYEDY 13.19
Required
Available
Ratio
Control
246.43 kN
926,338 kN
0.266
Web Plate Flexural Yield
408 mm
275 N/mm2
12 mm
110 mm
Required
Available
Ratio
Control
246.43 kN
728,794 kN
0.338
Shear Plate to Column Flange Weld Strength
in
11.315 mm
490 N/mm2
l
408 mm
is
110 mm
Required
Available
Ratio
Control
246.43 kN
1152.2 kN
0.214
Column Panel Zone Shear
429,124 kN
ÇYTHYEDY 13.29a
275000 kN/m2
28634.759 mm2
650 mm
16 mm
Required
Available
Ratio
Control
1379.649 kN
1716 kN
0.804
Panel Zone Thickness
t min ≥u / 180
TBDY 2018 9.3.4.2b
tmin = tw
16 mm
16 mm
u
2207.2 mm
Required
Available
Ratio
Control
12.262 mm
16 mm
0.766
