Select Entities Using Material
It selects the elements in which the relevant static materials in the project are defined.
Location of Select Entities Using Material
It can be defined and changed in the Materials line under the Structure Tree.
  • Open the right-click menu on structural material
  • Click the Select Entities Using Material command.
  • Depending on your selection, all elements in the file where this material is defined will be selected.
